Hi, I need some help with the switching supply on a BK Precision Function Gen/Lab Supply I got a while back in the US. After our move to Europe, I checked, and on the back the device claimed to be 120/220 50/60Hz compatible, so I went ahead and plugged it into 220v, and nothing! No bang, no sounds, no smoke,....just silence - the device will not turn on.
I opened her up, and there is a switching supply that has a bunch of jumpers and selection points - turns out, it was factory selected 110, and that I probably would have needed to do some mods before plugging in 220.
I connected the supply up to 110 (using a 500W step-down transformer), in its original configuration, and the output voltages are all very low (about 0.4volts, 0.2 volts, and 0.05). On the input side the voltages (120vac) are there.
The next step was to disconnect the supply board and inspect for blown fuses, burned, shorted, open resistors, charred tracks, etc. but it looks like not much power flowed through there at all - no signs of damage. Checked all the caps with DE5000, and all seemed OK with reasonable ESR. No bulges, etc. either. The board has no documentation that I can find, and no markings that show how to modify it for 220 volts. Neither can I figure out what is wrong with it in its current state (maybe it's just shut down when not connected to a load?) Any help regarding possible damage and failure modes when connecting to 220 Volts in 110 volts config, and ways to fix/reconfigure the supply for 220 would be greatly appreciated.
In the attachments, the last couple of photos show the jumper, and some pot (RJ) that might need changing. I am also thinking that the input bridge diode configuration might need changing to half the incoming power (to switch between 220/110?)
