Hello! I recently became the owner of an Extech 382260 variable power supply. I got this while picking up something completely unrelated from a yard sale. The previous owner had been using this for prototyping and something fried on him. As I am also prototyping electronics, I picked it up in hopes of fixing it.
Upon opening up the case I immediately noticed a blackened splotch, not unlike something from Looney Toons. It looks like this was caused by a particularly unhappy resistor. Next to the black splotch is an "R25" which looks to be the resistor that blew and there is a damaged R26, R27, R28 and D9 that look like they should probably be replaced as well as the voltage regulator. I've included a picture showing the unit and the damage:
I have tried to find information on the wiring diagram for this particular unit, but have had no luck. What I am hoping for is that someone might have this unit, and could open the case and take a look at the components that I listed above, and give me some information on them. For example...what is the resistor value for R25? Any information on the voltage regulator (lettering on mine is burnt off)?
Thank you in advance for any information you might have!
-Josiah
