Author Topic: [CLOSED] Chip identification  (Read 506 times)
Offline Andrew74Topic starter
« on: June 27, 2020, 06:32:29 pm »
I have a burnt up chip on a power command v and I am unable to determine the brand or part number of the IC. I have attached the images of the IC in hopes a grey beard can identify the manufacture. I can make out some of the part number; that being UAUB. The images are quite large, hopefully that helps :)
Update: The back of the chip had another part number: NTAF 1432. Image below.
Update 2: I think I have found the chip on Digikey by sheer luck...I'm ordering it now and hoping it will work. I will update this thread with the results just in case someone stumbles across this thread one day.
https://datasheets.maximintegrated.com/en/ds/MAX9924-MAX9927.pdf
Regards,
Andrew
« Last Edit: June 27, 2020, 07:24:12 pm by Andrew74 »
