Author Topic: chipped inductor still functional?  (Read 3839 times)
Offline WhiteFireDragonTopic starter
« on: November 22, 2015, 08:13:48 pm »
I have a audio DAC that has one of the top pieces cracked, however all the coils are still intact and tightly wound. Should I get it replaced, or will this not affect the functionality of it? Picture of the crack below:
Offline T3sl4co1l
    • Seven Transistor Labs
Re: chipped inductor still functional?
« Reply #1 on: November 22, 2015, 09:51:01 pm »
If U101 gets hot in operation (or other things act funny?), it should probably be replaced, yeah.
If the central stem of ferrite is cracked and loose, it should probably be replaced.
You can try supergluing the bits back on.  Ferrite and superglue work nicely together.
Seven Transistor Labs, LLC
« Reply #2 on: November 22, 2015, 09:57:55 pm »
So just to confirm, that part that chipped off does not provide any electrical or thermal functionality? The central stem and copper coils seem to be all good.
And can someone help me source a replacement for this damaged inductor? The only indication on the it is "102", and that's not enough info for me to find the same part number.
Offline T3sl4co1l
« Reply #3 on: November 22, 2015, 10:15:50 pm »
The black ceramic provides a path for magnetic fields.  By having somewhat less material, the inductance value will be lower.
It's probably not far out of tolerance (-20%, maybe?), which I would guess is still close enough for the nearby components.  But it might not be, hence my warning.
"102" is most likely 1mH.  The current rating will be determined by the wire size... which is determined by how big the thing is to begin with.  What diameter and height is it?
You could also check DC resistance, but it's probably under an ohm, so you'd need a special meter to be sure.
The package is a standard format from e.g. Bourns, etc. and probably costs under $1 (you'll spend more on shipping and handling).
Offline lukaq
  • Country: si
« Reply #4 on: November 23, 2015, 10:41:32 am »
you could super glue them back on, far better than not having them
Offline JoeB83
  • Longmont, CO
« Reply #5 on: November 24, 2015, 08:49:36 am »
Is that an ODAC? If so, the same happened with me, still works well.
