The 2SA1312 would fit package size and marking.
Here is the schematics I backed out. It looks like a normal PNP actually works in this place and it doesn't require a current mirror as I originally thought.
V1 and V2 are floating 5V supplies.
The OPAMP is an Elantec EL2075.
V3 is the voltage of the external UUT, e.g. a 20V power supply.
V4 is the sense voltage seen across the high side sense resistors. There are also low side sense resistors elsewhere, but they are only used for the MOSFET drivers to control the current they pass individually.
R1 is referenced to the low side of the UUT where the power MOSFETs are doing their work loading it.Their are five of these circuits in parallel, each sensing across a separate set of sense resistors that go to different pins of the load connector, but they are all shorted together on the load card.
With no voltage on V4, R1 gets about 128uA. This gets reduced by 27.5uA/mV on V4, so it's running out of head room at about 5mV sense voltage. The actual sense voltage is twice that since it comes in via a 50 Ohm source terminated cable.
This electronic load was meant to be used for load testing VRMs for motherboards and came with customized load cards (which I don't have). It is able to drain 300A, with a slew rate of 150A/us, so it requires very low inductance connections to the UUT.
