Author Topic: Circuit board, SOT23 component fault?  (Read 785 times)
Offline sailor83Topic starter
  • Country: no
« on: April 13, 2020, 12:08:20 pm »
I'm trying to figure out some errors on a Jungheinrich forklift machine. (ETV-Q20)
On one circuit board there are a few SOT23 components, are they always transistors? Everyone exept one give me diode readings. So I'm thinking this one might be faulty. (the others are marked 6B something, I've tried google to find out what type it could be, but no success..)
Are the SOT23 package always transistors or could they be something else?
Offline Manul
  • Country: lt
Re: Circuit board, SOT23 component fault?
« Reply #1 on: April 13, 2020, 12:26:17 pm »
SOT23 can be a lot of things. BJT transistor, mosfet, diode, dual diodes, zener diode, etc. Even IC's.
6B may be a BC817, but that is not guaranteed.
Offline JKKDev
  • Country: si
« Reply #2 on: April 14, 2020, 09:02:04 am »
Maybe post a picture of the board as it might be possible to figure out the function of the SOT23 from it's surrounding passives etc.
  • Country: no
« Reply #3 on: April 21, 2020, 08:11:24 pm »
It's the one with circle around..
Offline thm_w
  • Non-expert
« Reply #4 on: April 21, 2020, 10:41:47 pm »
Can you trace where the two connections go?
If it is BC817, then emitter is grounded which seems right. Top left pin would be base, right side pin collector.
https://www.sphere.bc.ca/download/smd-codebook.pdf
  • Country: no
« Reply #5 on: April 22, 2020, 07:05:57 pm »
Thanks! That pdf is something I've been trying to find :D
