I saw something similar with my own eyes in 2011. While inside the switching center, there was a power surge, UPS switched to batteries several times, but part of the network equipment still rebooted ...
Failure: WLC2106 Cisco Wi-Fi controller and switch Cisco C2960-48TC-L.
I read this bill:
https://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63770.html WLC2106 managed to exchange for a new one.
Switch Cisco C2960-48TC-L was not restored.
Moreover, in the course of life, other switch's began to come from other objects
(C2960G-24TCL, 2811..3500 ..).
About the RAM.
All the same, we are probably talking about NOR Flash-RAM , because the initialization by including by power ON.
There are no replicas on RS232 (ROMMON).
Make a clone using the programmer by reading the desoldered FRAM from the working device - it does not work out because MAC address (S / N) is protected, there is a protection bit and there are areas of checksums.
In addition, at the POST stage, the MPU mask is checked, which is read from the OTP MPU area.
In my opinion, it’s not really possible to do anything.
Vladimir.
