If all 4 ports are not working ( bit hard to tell if the rest is working either then, unless the serial connection still works) then at a minimum the big Marvell Ethernet chip is dead, deceased and cooked inside. unless you are able to replace this IC along with the cooked optocouplers and most likely the block of magnetics you need a new board from Cisco, or a new whole unit if they are not able to supply it, or a newer model if discontinued.
