Author Topic: Clean SMD lcd ribbon cable connector  (Read 1634 times)
Offline mau80Topic starter
« on: January 21, 2017, 03:29:26 pm »
Hi to all,
I'd like to ask your suggestion on clean two SMD lcd ribbon cable connector.
The connectors are a female 80 pin SMD ribbon cable connector mounted on LCD pilot circuit.
Some liquid, has been entered inside the two connectors and caused a short circuit between ribbon cable pins; now I'd like to replace the ribbon cables, but I've seen that some pin of the female connector present burned tracks.
I've tried to use a contact cleaner and a tiny brush, I've reach the result attached in the pictures.
I'm not sure that all pins are still present on female connectors,  I am concerned that the short circuit had burned out one pin; so I'd like to try to better clean the connector.
Can you suggest me same products or techniques to clean?
Thank you very much
Maurizio
« Last Edit: January 21, 2017, 06:08:30 pm by mau80 »
