I need some advice from the community regarding the cleaning (or not) of a Datron 4000 calibrator.
I bought a Datron 4000 from ebay. The device seems rather clean from the outside and the calibrator stickers from 2016 were intact.
A raw check of the outputs with a brymen869 multimeter didn´t show abnormalities.
Because of a fading diplay I decided to open it.
I couldn´t believe, what I saw: The device was very dirty/dusty inside!
The most dust resides on the backside (power supply, heatsink, fan), but also on the power-amplifier (see picture).
" alt="" class="bbc_img" />
The middle pcb´s were not so dirty, but one can see also a little bit of this characteristic dirt. On the display pcb is a litte more of this.
The dirt is mostly dust, so I could blow most of it away with compressed air.
But a small amount remained on the components - forming a thin layer of dry but a little bit greasy dirt.
Because I was sceptical, I "measured" the resistance of the surface of one of the big capacitors of the power amplifier, that also showed this layer of dirt.
I desoldered it and put 2 test leads with a distance of 1-1.5 cm on it (with some help of a hammer :-) )
Without humidity everything seems ok - but when I breathed on it, I could measure several megaohms.
If I clean the surface with a dry cotton pad, no resistance can be measured with the same procedure, so it is definitely a problem.
For a first test I started with a not so sensitive pcb, the power supply. I couldn´t remove the dirt layer completely with 99% IPA or "brake cleaner"
(from a car repair shop - my "weapon of mass destruction" for removing grease), even with the help of a brush.
Tap water with some dishwashing liquid worked a litte bit better. But I don´t feel comfortable with water and sensitive electronics...
And the main/chassis pcb is too big to put it in the oven for faster drying without complete disassembling.
So whats your suggestion for the other much more sensitive pcb´s ?
