Much safer to soak a piece of bond paper in Deoxit and pull that through the switch contacts..
Do NOT spray cleaner around the input attenuator section unless your intent is to destroy the scope. Tek warns about this in their service manuals for the 465 et al. It's apparently very bad for the capacitors.
