I just took pictures of this because I was curious as to what the de-oxide actually does, how effective it is on its own. I was pretty impressed!
Also, the spray leaves a thin lubricating residue. I usually just spray scratchy pots and switches with this.
In the pictures you can see, that it got rid of a lot of crud and oxides by simply spray-washing the contacts without even touching anything.
Just flood your switches with this and actuate it a couple of times.
