Author Topic: Cleaning RIFA guts  (Read 1356 times)
Offline BradCTopic starter
Cleaning RIFA guts
« on: March 14, 2021, 11:53:22 am »
My Tek 2440 scope got RIFAd, and it spilled its guts all over the board.
I've alternated between Ethanol, Isopropanol and DI water with gentle scrubbing, but there is still some residue and a particular stench that I can't seem to shake. Does anyone have any magic fluids that are likely to make this job easier and less smelly?
Online PA0PBZ
Re: Cleaning RIFA guts
« Reply #1 on: March 14, 2021, 01:10:25 pm »
Just to make sure that you know what you are looking for:  ;D
« Reply #2 on: March 14, 2021, 01:50:55 pm »
Oh this wasn't a "boom". This was a "slow cook". I turned it on to warm up, and then went outside to do other stuff. It certainly "warmed up".
The sludge on the board was/is vile, and the smell is pretty noxious. I didn't use gloves to take that pic, and after 3 washes I still can't get the smell off my fingers.
A "few" years ago my HP 3457a got "Schaffner'd" and left a stain on the wall and a smell that took a while to dissipate. This was much worse, and as it was 38+ degrees outside the house was closed up with the A/C on. As I was outside when it went, and the fan managed to beautifully purge the smoke into the room which was then circulated throughout the house. The "Wife Approval Factor" (WAF) on my choice of test gear was not high. Moreso when I told her I'd picked up the bits in 2017 to do the 'scope and the pair of HP 3478a meters because we didn't want that "Schaffner" smell again. You can't rush these things.
Still, an opportunity to re-cap the PSU and replace the 29 year old DS1230 NVRAMs.
Offline Per Hansson
« Reply #3 on: March 14, 2021, 05:08:29 pm »
I have not had the misfortune of these failing on me so I don't know the usefulness of this recommendation but what about using acetic acid (vinegar) to clean it up?
It is a pretty strong acid and takes care of most things in my experience :)
« Reply #4 on: March 14, 2021, 07:42:43 pm »
The stuff is fairly difficult to get off. I just left it there when I had one blow  :-DD
Offline Gyro
« Reply #5 on: March 14, 2021, 08:19:37 pm »
The dielectric is paper, so I think the mess is burned epoxy residue. I'm not sure how much that helps, but probably explains why it's so hard to clean off.
Best Regards, Chris
The following users thanked this post: najrao
« Reply #6 on: March 14, 2021, 08:25:10 pm »
Makes sense. It stops stinking after a few days as well which is handy.
Offline jdragoset
« Reply #7 on: March 14, 2021, 09:53:14 pm »
Try very small test sites with various solvents:
Charcoal lighter (distilled kerosene)
Coleman fuel (naptha)
Acetone
Goof Off (acetone/Xylene)
Nitro Benzene (gunpowder solvent)
Brake cleaner (various solvent mix)
Carburetor cleaner (various solvent mix)
When I say small I'm talking about the point of a toothpick.
When you find what works, apply it very carefully where it is needed.
Follow up with other solvent of the above(if necessary), IPA and DI water rinse and bake dry
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #8 on: March 14, 2021, 11:13:07 pm »
In my experience the stench doesn't disappear for at least 2 weeks.
« Reply #9 on: March 15, 2021, 03:48:09 am »
Yeah, it has been over a week and the inside of the scope still stinks. I pulled the PSU the day it happened, so it's just the smoke that has left the residual smell.
Offline perieanuo
« Reply #10 on: March 15, 2021, 11:03:40 am »
acetone rules, except missing labels afterwards :)
Offline wiesl
  • Country: at
« Reply #11 on: March 16, 2021, 02:39:41 pm »
Thankfully I replaced all RIFAs  :)
Online Haenk
« Reply #12 on: March 17, 2021, 01:11:39 pm »
Rule of thumb: Always open and check for RIFAs before powering older stuff up  :horse:
(Though I have to admit I recently powered up an older calculator with a RIFA in it and didn't bother to replace it due to being sold and the buyer being warned). It wasn't cracked (quite a miracle) and it didn't explode (another miracle) after laying dormant for 40 years or so...)
