Hi all.
In the process of attempting to restore an old Fender Bassman amp.
Lots of mickey-mouse work done already..hope I don't make it worse.
Half the screws are mix & match..and worst of all..looks like acid core solder on the odd joints.
I'll remove/clean up the solder hacks, but..the tube sockets seem flaky..they're not burned at all ..just oxidized.
(And yes, replacing the electrolytics, which actually aren't leaking/that bad)
I Do have Deoxit D5, but was wondering if anyone uses..or if they're available....some kind of a very fine brass (or WHY) tiny pipe cleaner(s) for cleaning the individual tube pin sockets?
Is it a bad idea?
Opinions?
Thanks in advance!
