Author Topic: Clearing error logs on Tek MSO DPO 3000 series.  (Read 2608 times)
Offline JwallingTopic starter
  • This is work?
« on: June 08, 2015, 10:36:38 am »
Hello,
Does anyone know how to clear the error logs on DPO or MSO 3000 series of scopes?
I have an MSO3034 that has a number of front panel errors from 2010 that I'd like to clear.
Looking through the firmware, there are these commands:
:ERRlog:FIRst?
:ERRlog:NEXt?
Those are obvious...
:ERRlog:FILL
Don't know what this one does - when I tried it, didn't seem to do anything.
There does not appear to be a :ERRlog:CLEar as is present on some older generation Tek scopes.
Tried it anyway, but it didn't do anything.
Thanks.
Jay
Jay
System error. Strike any user to continue.
  • This is work?
Re: Clearing error logs on Tek MSO DPO 3000 series.
« Reply #1 on: July 25, 2015, 11:04:32 am »
So, I think I could probably find the errorlog if I could gain access to the filesystem via telnet.
Looking through the version 2.40 firmware from Teks site.
Inside the image is the actual firmware in a file called filesystem.tar.gz
In the directory /etc/init.d is a file called rcS, is the following bit:
# We no longer start up the micro telnet daemon for security reasons.
#/usr/share/tek/utelnetd -d
I could modify this to enable telnet, but utelnetd does not exist anywhere in the file system so Tek must have removed it at some point.
Oldest firmware on Teks website is 2.31, but this firmware does not have the telnet daemon either.
If anybody has some older firmware they could take a look at, perhaps it was in earlier versions? :-//
Jay
Jay
