Author Topic: CMT-EX1 power supply connector  (Read 308 times)
Offline Frank OceanTopic starter
« on: July 05, 2023, 01:36:48 am »
Here's a power cable from a Cmt-ex1 Sony CD player. This connector used to be connected to the inside of the power supply. However, I had to disassemble it because I needed to replace the motherboard for the CD player. I found this CD player at Goodwill, but the wire was poorly connected with a completely different cable. It was patched together using electrical tape and wire connectors.
The original cable was called E81093 (UL) NISPT-2 VW-1 105C 2X18AWG, C(UL) NONINTEGRAL SPT-2 FT1. Also the yellow plastic says Amp with a + on top of the M. this CD player is from 2000
if there isn't any answer to that, how could i properly Frankenstein another cable to it without looking somewhat ugly
