I discovered in my CMU band gap in freq. range ~1.2G - to ~2.2G. In general I've found post by RF_fanatic:
https://www.eevblog.com/forum/repair/rohde-and-schwartz-cmu200-rxtx-module-issues/50/Indicating that board 1100.2500.02 causes failure.
In general I've removed this board from equipment - there is not to much on it, the ICs are 4 x AD829J, 4 x NE5534, 2 x AD835A, 1 x AT24C164. Additionally 2 diodes and pnp transistor. The rest is passive - resistors, capacitors, chockes.
Has anyone trying to repair this board ? In general its interesting, as these components do not seems to be used in some high freq. range - but maybe.
Sometimes internal bonding in ICs can fail after some temp./vib. rapid changes...
Of course I can check part by part but desoldering - soldering to test board - desoldering again and soldering again does not look optimal. So first check here in forum...
BTW. Has someone EEPROM content for it (I mean this 24C164 located on it) - that is my 1st suspected.
Regards,
