Author Topic: CMU200 PSU erratic ON/OFF  (Read 4111 times)
Offline BeOTopic starter
« on: April 18, 2017, 07:33:22 pm »
Hello
I am new on this forum , I try to learn RF and built a Ground Radar as project
I have purchase in 2016 on Ebay UK , one CMU200 which have failed , power supply have failed , thanks to Ericmax on this forum for repair tips BUT after repair
my actual situation is :
my CMU 200 -02 : it's start normally and works fine regarding both spectrum and generator but it auto switch off when it wants by a similar way I press the one ON/OFF button ( shutdown in progress and now it s switch off at the bios screen level
I have all the power supply green LED OK
I have change the TI SOIC 10 on the main board in case off but no change regarding the auto switch off
I have check the ON/OFF button , soft PCB is OK
I have check all connectors , nothing wrong
I have remove signal group cards ''option'' to eliminate possible ''short'' but the defect is still the same
Now ( 20 April ) after several power ON power OFF trials ;
PSU start OK
Green LEDs on base board are OK
BUT
I go straight from orange to green led on the front panel ( ON/OFF ) , and nothing start
I am very disappointed by R&S multiples failures cases , and the fact that the maintenance manual is not available
BeO
« Last Edit: April 23, 2017, 09:33:09 am by BeO »
Re: CMU200 PSU erratic ON/OFF
« Reply #1 on: April 23, 2017, 09:27:46 am »
Hello
I have succeed to locate a copy of the service manual , problem seems to be the lithium battery flat on the computer board , I will run a disassembly and battery identification to order a new , there is two battery model possible on in 3.6v and one in 3V
I will post the result soon
Thanks
BeO
« Last Edit: April 23, 2017, 10:03:55 am by BeO »
Offline richnormand
« Reply #2 on: April 23, 2017, 09:04:30 pm »
You might want to go through this thread about PSU issues.
Not the main theme but several replies do seem to address some of  your problems.
https://www.eevblog.com/forum/repair/rohde-schwartz-universal-radio-communication-tester-cmu200-psu-issues/
As far as the "service" manual all I have is pretty generic and not that useful as it only includes high level flowcharts.
Is yours including actual schematics?
I collected quite a bit of info on the CMU200 so let me know if you want to get in touch. Also in that thread, and another one I started on the RxTx module, you will find links to people that know a lot more about the CMU200 that I do.
PS: does BeO refer to beryllium oxide?
« Last Edit: April 23, 2017, 09:06:29 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
« Reply #3 on: April 24, 2017, 10:31:23 am »
Hello
thanks for your feedback
my CMU have start to generate self ''automatic shutdown'' more and more quicker so the explanation regarding battery fail looks reasonable
I have switch PSU from my other CMU200 ( I enjoy problemss 8) so that a ''250'' which works on my other CMU200/30 , nothing change same defect . green led OK , no start
I will try to track on/off button on the computer board
I agree regarding the service manual that not a detailed service manual , th ereal serice service manual with all schematics and circuits is the ''module service manual## I try to loacte one copy , but as this ''module service'' is a true internal doc from R&S that look difficult
This afternoon I try to change the battery and restart the CMU200/02 and will post regarding the result
BeO
« Reply #4 on: April 24, 2017, 05:49:57 pm »
Hello
Afternoon progress
I have change the Lithium battery for a new one ( CR2032 ) as the installed one was clearly dead
NO change
But when I have manipulated the CMU200 , the defect have changed as self restart trials. shutdown ....  , front panel keyboard shows to be very sensitive effect around On/Off and F1 touch
after to have disassembled the front panel the flexible PCB was corroded on one track between on/off and F1 touch
I have switch the flexible PCB by using the flexible PCB of my other CMU200 (30 ) and now the CMU200 works fine
Flexible PCB of the keyboard looks very sensitive to corrosion as the membrane is very thin and area arround on/off / F1 is stressed by numerous use
As conclusion now my CMU200 / 02 works gain
I now search to locate a spare flexible PCB in good shape to complete my CMu200/30 and solve boot problem
I have a signal unit available which was removed from another CMU200  if that can help someone
Best Regards
BeO
Offline RF_fanatic
« Reply #5 on: June 24, 2017, 10:16:50 pm »
Just read your topic for first time. Indeed your behaviour sounded like a foil issue. It is a often occuring problem, most of the time manifested by a shut donw when pressing other buttons on the row on the bottom.
I have seen replacement units for the front foil, made by a chinese (?) guy. He copied the foil on a very thin PCB board including an added flexible part for the connector. That would be an option as foils are very hard to find!
But I can'n'r recall where I found it. I know it were CMU for sale for which he had made the above boards
Offline Qw3rtzuiop
« Reply #6 on: September 29, 2017, 09:22:23 am »
« Reply #7 on: July 07, 2018, 08:20:23 am »
Hello
Thanks for the link
I have order one from R&S the cost is 170 Euro
Regards
BeO
