Author Topic: CMU200 serial number  (Read 3110 times)
Offline RF_fanaticTopic starter
« on: May 18, 2017, 06:54:18 pm »
Does anyone know where the serial number is defined?
I have one with serial number 000000 so obviously it losts it's orginal serial number, it happend  after an unsuccesfull firmware update board change.
I checked the swop and identity file but no clue at this moment.
Anyone help would be appreciated
« Last Edit: June 24, 2017, 09:32:32 pm by RF_fanatic »
Online Nusa
Re: CMU200 serial number
« Reply #1 on: May 19, 2017, 08:03:49 pm »
See if you can spot any resistor clusters that differ in values between two mainboards. That could be a serial number. Much harder to spot than jumper pads. I remember Dave found some option pins done that way on a Keysight scope teardown a couple months back.
Offline Bicurico
  • Country: pt
    • VMA's Satellite Blog
« Reply #2 on: May 19, 2017, 08:10:38 pm »
I m on my phone so here is a short quick reply.
Try booting into the service menu and run the maintenance.
Regards,
Vitor
« Reply #3 on: August 12, 2017, 09:07:33 pm »
Gentle BUMP :)
Stil got serial 000000 :(
Doe anyone know how to change it back into the original number?
Offline Qw3rtzuiop
« Reply #4 on: June 29, 2018, 09:13:40 pm »
@RF_fanatic
Any success? I suspect that the serial number is stored on the FMR somewhere. Its not stored on the HDD.
« Last Edit: June 29, 2018, 09:19:12 pm by Qw3rtzuiop »
