Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
CNBOU 1KW inverter blown resistor
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: CNBOU 1KW inverter blown resistor (Read 659 times)
tsumasuko
Newbie
Country:
on:
July 26, 2024, 10:43:24 am »
hi all,
i have a CNBOU 1KW inverter for repairing. there is a blown resistor that cannot read the value. i need help who someone have same product and eligible to tell me what is the value of this resistor.
thanks for any help.
Logged
beatman
Regular Contributor
Country:
Re: CNBOU 1KW inverter blown resistor
Reply #1 on:
July 28, 2024, 11:05:32 am »
It looks like the aishi capacitors are bulged?Try to search for service manual with the model name or the board printed code or a member have the same machine and can help.Other option is to cut carefully with knife the resistor in the middle and measure the two halfs and from both numbers you have about the whole resistor number.
Last Edit: July 28, 2024, 11:11:00 am by beatman
Logged
Phil1977
Frequent Contributor
Country:
Reply #2 on:
July 28, 2024, 11:27:13 am »
Out of all the components in the inverter it´s very improbable that the resistor has caused it´s own death. Even if you find the right value you will have to do more failure analysis.
Logged
tsumasuko
Newbie
Country:
Reply #3 on:
July 28, 2024, 07:04:11 pm »
yeah there are some parts broken. you saw these 2 caps and 2 more on the other side are bulged. replaced already.
also find 2 mosfets(40N60) failed out of 4.
this burnt resistor stay in between 12V input and PWM (SG2525) control board. looks like fuse resistor. i tried 4.7 ohm/3W but nothing happened. no short circuit by the way. ordered pwm chip and i will try again.
Logged
tsumasuko
Newbie
Country:
Reply #4 on:
August 08, 2024, 10:46:38 am »
Hi all,
i am here for quick update.
Instead using a guessed resistor i just added 160mA resettable fuse and changed the other broken parts that i mentioned. now its working fine. thanks for helping..
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
