Hello All!
The toolarm of my cnc mill is not always coming out. To be precise: 9 out of 10 it doesn't. I didn't figure out any pattern: Temperature, time of running etc.
while try to find the error I measured if there is enough voltage on the motor and accidently figured out a workaround:
When the Fluke is in AC mode and I measure between pin 29 and 32 it ALWAYS works!
While this hack gets me going during the week, when people are around to hold the fluke to the contacts, I can not work on the weekends when I am alone. I tried to add wires to the contacts JP11 2A and JP11 3A and the fluke. That DOESN't work - I littarly have to hold the pins from the Fluke to the contacts like in the picture shown. Strange...
Does anyone has an idea how to fix this? Any suggestions are much appreciated!!
Thanks, Duesentrieb
