Author Topic: Cobra 240.1 HS E/S  (Read 263 times)
Offline LoidTopic starter
Cobra 240.1 HS E/S
« on: May 21, 2024, 11:03:08 am »
Hello i have problem with my shredder,that make strange noise and the chain "jump" on the gear. I also post a video how its looks like. I already replaced chain
https://youtu.be/JTIxEWEjpWY?feature=shared
Offline Haenk
Re: Cobra 240.1 HS E/S
« Reply #1 on: May 21, 2024, 11:35:48 am »
Judging by the pictures, there is not enough tension in the chain. Jumping occurs when either the gear teeth are worn or the chain does not have enough tension. Usually, there has to be either a chain tensioner, or some adjustment mechanism. There never should occur a slip in the chain driven, as this will then certainly damage the chain and the teeths.
Maybe check for wear on the chain as well, these chains can lengthen over time and then need to be replaced.
