Hi, your original question, the relay does not get the 12V.
And now, the Relay is energized.
So problem solved?
You know without the schematic and the front panel, I don't know what LED 24 is for also.
Arm, I had all this info typed out that took me a half an hour,, got distracted , hit a wrong key on the keyboard and it all went away. I'll give you the condensed version now. If you need more info let me know.
The full number for that IC is
P 49SB
MM74HC
14M
I tested the voltages on Q1 and Q2. only difference was on Q2. Dut - C=.569 New C= .717. all other readings were the same.
When testing the voltages on the dut, I tested the coil voltage and had 12 volts all of a sudden. WTF? I then took the dut and soldered the relay back on the board. I hooked up a 50 watt lamp to the relay.
Hooked everything back up. Powered up. led9 lit up (not ready) .Led 24 (over next to Q1, hidden by the membrane switch, never noticed it before. this led never came on.
After 4 or 5 seconds, the lamp came on! Its working! Why now, I have no idea. With the lamp on (calling for heat), I got my heat gun and heated up the temp probe. After 10 seconds led 9 turned off and the ready led lit up . The lamp shutoff at this time. Ok, appears to be working. Let the temp probe cool down after a few seconds the ready lamp goes out and the not ready lamp lit back up. At this time the lamp should of came back on (calling for heat again, but it never did. Unplugged it a few times. Never could get the relay to make after this. Confused more than ever.
What do you make of this Arm
