It's a green flash lamp pumped NdYag. It's from 1997 if that's any help
But I did actually figure out how to get a description of the error codes. There is a switch labeled "service" on the board, flicking that once the board has gotten stuck at the error code makes it show the gui anyway. That then actually sais what the errors are.
Mine happened to have a seized pump and a "power supply did not calibrate" error which came from a broken optical control line to the HVPS. Fixing those two issues seems to have repaired the laser
