I'm halfway through repairing this, I'm a bit stuck so thought I would make a post while I do some more research. I'm not sure if there is a fault or not.
Originally I was just going to do a recap, upgrade the trimpots and replace R421, R422, R423 and R424 because they were cracking from too much heat. But after testing I found one of the channels was much quieter than the other and breaking up. I'm not sure which channel it was, I don't really want to plug it into my speakers again in case it blows them up. I thought it might just be the volume / balance control trimpots that need cleaning but after checking voltages against the schematic I'm not so sure.
1 - R421, R422, R423 and R424 were damaged from too much heat (outer layer was cracking off some of them). I replaced them with new 0.25W resistors, but I found R42 and R422 dissipate 0.22W which seems a bit close. I think part of the problem is the A and B rails are unregulated, they are meant to be +/-35V but mine are closer to +/-37V. I measured the line voltage as 245V AC and the voltage selection switch is set to 240V AC. It seems like it's a design issue or the original resistors were poor quality? Maybe I should replace them with 0.5W versions?
2 - I've trimmed the bis voltage to about 33mV as outlined in the service manual (across R447/R445 and R446/R448). But the voltage is not evenly distributed across the current sense resistors, giving me about -7mV DC on the output to the speakers. I've attached a schematic with the voltages annotated, it's the emitter voltages of Q427, Q429, Q428 and Q430 I'm most concerned about. But the base voltages for Q401, Q403, Q402 and Q404 are far from the nominal values listed, and the current sink on their emitters is off too.
Does it look like there's a fault? Or is it just that the A and B rails are above nominal? I expected to find differences in voltages between the L/R channels, but they seem fairly similar.
edit: I was going to attach the service manual but the file size is too big, it's available here:
https://www.hifiengine.com/manual_library/harman-kardon/pm640.shtml
