Hello All,
I'm trying to repair a color display issue which could be a double failure (A30 color display driver) and A11 main board (video section).
Symptoms: the TDS784C works fine (boot, SPC, self-test...) but the color CRT will stay kind of blueish with some bands flickering. However if connecting an external VGA screen, the video display works fine where in fact that was the only method to check self-test and usage.
Preliminary testing: since I do have another TDS794D which works wonderful in color, I've swapped each main board A11 where the TDS794D has good CRT and driver. Installing the good A11 board into the TDS784C will kind of show the CRT with some faint flickering (no more blueish) but the external VGA output works fine. Same situation of the partial failed A11 board from TDS784C installed inside the TDS794D will not have CRT to work. So it seems a double failure issue somewhere of my TDS784C, video section of the A11 board and A30 display driver board.
One option would be to purchase the LCD kit from USA made by SimComm Labs, it is a hacking of the A11 video section and using power supply rails from the J5 connector. One hypothesis being that if the external VGA display works then the LCD kit could work and offer less weight, less power consumption plus less failure in the future of the display.
Unfortunately there are no detailed schematics on internet regarding the TDSxxx serie C and serie D, the only document found is the TDS320B component manual but it does not contains the color section.
I did take some time to analyze or reverse the wirings of the J5 connector (video signals and power supplies) between A11 main board and CRT display driver. Since I do have as well a working TDS540C and TDS520D (Acquisition board failed only), I have compared the J5 signals between color versus mono:
D1-D2: +26V (open load)
D3-D4: +5V (open load)
D5-D6-D7-D9-D11-D12-D15-D16: GND
D8, D10, D13 and D14: unknown
The A11 color main board has an additional connector J62 (Signal and GND) connected to A30 board plus of course more chips to manage the color generation including an additional 80MHz quartz (Y3) not found in the mono-A11 board.
As for the D13-D14 pins of the J574 (mono), they are shorted whereas on the J390 they are not electrically linked.
What is your opinion of what is wrong with this color display failure and do you think it could be solved by replacing the CRT unit and driver by the LCD kit ?
By the way, does any of you have tried connecting the J5 output from a A11-Color board to a A30 Mono-CRT-driver where it seems most of the 16 pins are kind of same defined except few ones ?
Thanks, Albert
