Hello everyone,
I have an original model Commodore 1084 made in 1987. These are with original Philips design with HR 6489 fly-back and external focus unit on neck-board.
Immediately after I turn it on, the monitor works with no issue but after half an hour or so when it gets warmer; a flicker/jump happens on screen and image goes back to normal. This happens only once every few minutes. Artifact looks like monitor getting out of sync momentarily and recovers.
The issue does not happen when the CRT cover is off. With cover off, I can only make it happen using a fan-heater to increase ambient temperature. To look for any arching I observed the boards and the tube in a dark room, but did not see any arching, the only thing I can hear is a very soft static noise due to resyncing. I have reflowed the solder on fly-back pins and checked for any voltage leakage in HV areas with a probe.
Many similar post suggest replacing the fly-back, however I rather be sure before before purchasing the new fly-back and do all solder/desoldering work.
I have an oscilloscope and was thinking to check horizontal and vertical sweep signals while this happens; but I am not sure where to start and how to set the trigger for waveform capture.
I look forward to your hints or suggestions.
