Hi all,
On to my next issue - ah, the joys of owning classic machines
- my C128 seems to have a colour problem in that when the machine is first turned on, it will sometimes appear in black and white. After a while the green of the C128 main screen will appear but not in a uniform manner. There will still be patches of white along the border. If left on long enough, all the green will appear.
So far, I know the lead, monitor and power supply are fine as I have tested the with another 128. I have also checked the large 4 capacitors on the board near the power switch. They all tested fine but I decided to replace the 220uF and 100uF as I has replacements for those. None of the ICs seem to become very hot or even very warm.
What should I check next?
