Author Topic: Commodore 1701 monitor - bowing at the top of the screen  (Read 1498 times)
Offline aa7aeTopic starter
« on: November 21, 2022, 05:40:31 am »
I just completely replaced all the capacitors in this Commodore 1701 monitor.  Before I replaced the capacitors, the image geometry was missing part of the bottom of the screen, but it looked fairly ok otherwise.  After I recapped everything, now I have this bowing going on at the top of the screen which I don't know how this started. I have tried all the adjustments I can find, but this looks like a more complicated problem with the yoke.  Thoughts anyone?
Thanks
« Last Edit: November 21, 2022, 05:44:04 am by aa7ae »
Offline inse
Re: Commodore 1701 monitor - bowing at the top of the screen
« Reply #1 on: November 21, 2022, 06:02:03 am »
There is also an issue at the bottom of the screen.
Is the diagonal line and the ghost image at the top real or some camera exposure or reflection  issue?
« Last Edit: November 21, 2022, 06:06:06 am by inse »
« Reply #2 on: November 21, 2022, 06:18:50 am »
The diagonal line seems to be an artifact of taking the picture with my phone.  The lines at the top where the bowing is occurring is real.
Offline inse
« Reply #3 on: November 21, 2022, 09:44:28 am »
Can you post or link the schematic of your set?
« Last Edit: November 21, 2022, 03:22:43 pm by inse »
Offline inse
« Reply #5 on: November 21, 2022, 09:21:28 pm »
Can you check the B+ voltage (110V) for stability?
Offline m k
« Reply #6 on: November 22, 2022, 06:31:26 pm »
"COMMODORE BASIC" and "BYTES FREE" have different postures.
Have you adjusted h-lin?
Is the shape equal if you turn the service switch?
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-OR-X-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
« Reply #7 on: November 23, 2022, 03:47:14 pm »
After Thanksgiving, and with the arrival of some more parts, I'm going to go through and verify all the caps I replaced and check things with a voltmeter.  Will be using an isolation transformer.
« Reply #8 on: December 04, 2022, 04:57:31 am »
I have adjusted the B1 voltage to be on spec, 110v.  I have also changed out a few more capacitors around the IC responsible for horizontal and vertical sync as well as changed out the IC itself. No difference.
I made further adjustments to vertical size, linearity, and so forth with limited success.  It's a little better.  There is also some odd black raster lines visible on the screen as well.
Offline amyk
« Reply #9 on: December 04, 2022, 08:29:15 am »
Is the distortion dependent upon the content being displayed? In your example image there are lines at the top where the duty cycle of the gun is reduced due to the black text, which seem to coincide with the wider portions.
« Reply #10 on: December 04, 2022, 06:27:45 pm »
Yes, the distortion is still there regardless of what game I play or image is on the screen.
« Reply #11 on: December 04, 2022, 10:11:15 pm »
I have discovered what the problem is.  The schematics aren't accurate.  In the pin circuit, the schematic shows two capacitors in parallel C517 and C518, however in real life, there is no C518 capacitor.  Since I was going off the schematic, I installed a 47uF capacitor for C517, when it should have been 470uF as shown on my parts lists on the internet. I could not understand why these things did not jive until I saw there are no parallel capacitors. There must have been a change to just go with one capacitor of a larger value which was not reflected in the schematic.
The following users thanked this post: m k
Offline inse
« Reply #12 on: December 04, 2022, 10:31:25 pm »
Great, finally you fixed it
Offline m k
« Reply #13 on: December 05, 2022, 06:40:33 pm »
1702 has 470/25 there.
