Author Topic: Commodore 64 power supply repair.  (Read 4478 times)
Offline BashstreetTopic starter
« on: December 29, 2017, 12:31:08 pm »
Hi all.
I been working on making a replacement power supply for my loved C-64
All is fine and dandy but i have bit of hiccup with the 9 volt AC that it requires.
I bought a 9 volt transformer but as it is unregulated even under load with the commodore it gives some 11.5 volts.. Quite a bit from where i ideally want to be...
Chematic
http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/c64/250469-rev.A-left.gif
http://www.zimmers.net/anonftp/pub/cbm/schematics/computers/c64/250469-rev.A-right.gif
By looking the schematic i do not see anything too sensitive on the 9 volt lines.... but have a look.
I would ideally want to regulate the 9 volt line to... well 9 volt but it needs to stay AC as the 60hz is used internally in some timing functions.
How one regulates AC without effecting it's frequency ?
Cheers.
Offline anachrocomputer
Re: Commodore 64 power supply repair.
« Reply #1 on: December 29, 2017, 02:14:21 pm »
The original C64 PSU may well have been a simple 50/60Hz transformer in a box. See if you can find the original schematic.
Now, a typical mains transformer is rated at full load, and has a regulation of typically 20%. That means that a nominal 9V AC transformer is designed to produce 9V when fully loaded at its rated current. If it's unloaded, the voltage will be higher. The 20% load regulation spec means that there will be approximately 20% variation in voltage between off-load and full load.
Remember that there's also some allowable variation of the input voltage (mains voltage) and if the input is a bit high or low, the output will be too.
Offline stj
« Reply #2 on: December 29, 2017, 06:16:18 pm »
the original was a transformer with several windings, combined with a 7805 on a useless heatsink.
useless because they potted it!!
Offline Rasz
    • My random blog.
« Reply #3 on: December 29, 2017, 07:18:19 pm »
first half is about c64 supplies:
The following users thanked this post: Bashstreet
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: December 30, 2017, 01:03:54 am »
The 9VAC is rectified internally to feed some linear regulators. They are already running quite hot. I made my 64 power supplies with the 9VAC transformer from the 2-pin VIC-20 power supply.
However, if you have a broken C64 power supply, there's your 9VAC transformer. Simply remove the bad 5V and splice in a good regulated 5V 2A wall wart into the power connector.
That's what I do now.
Offline stj
« Reply #5 on: December 30, 2017, 02:28:08 am »
i fixed one once by mounting a heatsink on top with a 78s05 and wiring it to the exposed pcb pads inside after cutting the old pins.
i wouldnt do that now though - the caps are too old to leave in place.
