Hi All,
I bought the Dolce Gusto Piccolo. After a time, I found that the temperature of the water is not hot enough to proper extract the coffee.
After searching internet I found that the right temperature is from 92 to 96 C. But my coffee machine have only 80.
I made some researches about Dolce Gusto Piccolo, and I found youtube video, about how the machine look inside :
Schematic from the youtube link : 20170111_175537.jpg
I measure the little temperature sensor is a NTC element - 10 k Ohm. By adding the series resistor 820 Ohm, I change the PID goal temperature to the 93 C.
Adding the resistor DSC_0656.JPG - to setup right temperature, by try and change.
See the running machine after changes :
https://youtu.be/KdGcTu1xn_YThe little coffee machine work for now perfect
