I saw Jerry's post and video at these links:
https://www.eevblog.com/forum/repair/ac-motor-question/msg5080822/#msg5080822but decided a new post with my particular situation was appropriate.
Jerry, thanks for the video of your DeWalt vacuum motor and its sparking carbon brushes and commutator. How is your repair work going?
I have a Miele domestic vacuum cleaner that recently started doing exactly the same things. Sparking, burning smell, slowing down. It's 29 years old, a beauty and worth repairing, if only to be retired honourably to the garage. For search engines, it's a Miele vacuum cleaner model S448i (S400 series) and is called a White Pearl. It has a Miele 230V motor, not an Ametek motor.
Here's a still shot, sans sparks, at the latest state of repair and after the latest test.
My repair efforts have not yet succeeded and I'm looking for clues. Here's what I've tried.
- the carbon brushes were worn out. No, they didn't last 29 years; I'd replaced them with Miele spares about 15 years ago. Presently, one of them had become too short and due to the spring stop inside the brush holder the spring could no longer push it reliably against the commutator bars. To investigate, I bent the tabs that stopped the spring moving, to reinstate spring pressure for that brush, but the sparking continued. I now believe the heavy sparking from the initial failure event damaged a few of the commutator bars, which has proven difficult to deal with. The reply from Johansen on Jerry's thread supports this.
- Miele no longer supply replacement brushes. I found carbon brushes of the right size on eBay, though they need to be soldered into the old holders. Easy enough. I do wonder about the composition of the carbon and its suitability. I saw somewhere that Miele brushes are 'special'. Really?
- Investigation of the armature and commutator revealed several problems, in stages. The obvious ones were that there was a deep groove in the commutator from being rubbed by carbon brushes for decades, along with the commutator bars being somewhat blackened, though they didn't look too bad. Later I discovered that a few of the bars were sitting lower than the others. Further, the whole circle of 24 bars was discovered to be out of round. Tests for resistance between adjacent bars, opposite bars and between bars and the armature body are all good. The on-motor circuit board and its components (a capacitor, a heat sensor and a triac) are good. The bearings are good. The vacuum cleaner's speed control circuit board is good.
I tried several repairs. First, I put the armature in a drill press and cleaned the commutator with a strip of sand paper (not emery paper). It was very shiny but running the motor for a few seconds with the old brushes that were making good contact resulted in heavy sparking. This step showed that some of the bars were possibly low; they didn't pick up the light-brown coating that most other bars did. While waiting for the new brushes to be delivered I went to work on the commutator. With a drill press I filed down the high zones at each end of the bars, to remove the groove and so that the new brushes would not be pinched. I mounted my drill press on its side to make a crude lathe and used a jig to ensure strips of sand paper would be held steady and would touch only the high spots of the commutator as it rotated. Slowly and gradually I made the commutator and its bars level, round, shiny and on axis. I've added a lathe to my shopping list. Apart from the bars being way lower than original, it looked new. I cleaned the gaps between the bars. I held one of the old carbon brushes against the bars and it ran very smoothly over the surface.
I installed the new brushes into the old holders and partly seated these by spinning the motor in my hands with a battery drill, with help from a beautiful assistant. Everything looked good. My expectation was that the vacuum cleaner would operate, as it had with each repair test, but I was not confident that the sparking would be absent. And so it proved to be. I started the motor for brief runs at the lowest power setting, to bed the brushes gradually. As per earlier tests, after running nicely for a few seconds the heavy sparking would begin and not stop and the motor would slow down.
I'm a bit stumped.
I've thought about how a commutator needs to be perfectly round so that carbon brushes won't bounce or skip over lower bars at high revs, which would result in sparks. I've thought about how brushes get pulled slightly sideways in their holders and how, once they are worn-in, will make contact with adjacent pairs of bars. I've thought about armature and commutator wiring, inter-bar continuity and lowest paths of resistance through windings. I'm concerned that this Miele's commutator is worn down too far (and more so from my repair work) to the point where it might not be capable of functioning properly. Repairable commutators have limits. I'm looking at sourcing a replacement commutator and whether I can install it with the existing armature windings in place (to avoid balance problems), or will need to re-do the whole armature winding (and re-balance?)
The street vendors in India and Indonesia I've been watching online are not as careful as I've been with my repair. Their roughly repaired motors don't spark like my Miele motor does. They might not be showing their failures. Hmmmm.
Has anyone had success with replacing a commutator, with or without re-doing the armature winding? Motor repair guys do this for a living, so the answer must be Yes. This sounds like a fun challenge, but could be a pointless one. I don't want to declare the patient dead just yet; there are sufficient signs of life with each resuscitation attempt.
Your thoughts and clues would be appreciated. Thank you. Valden.
