Author Topic: Component identification  (Read 26299 times)
Offline Hornnumb2Topic starter
« on: January 12, 2024, 02:38:17 am »
I tried to google the chip number but no luck, of course I haven’t a clue what it is try and find it. Thanks Michael
Offline FactorySmoke
Re: Component identification
« Reply #1 on: January 12, 2024, 02:45:10 am »
Measure the exact dimensions of the plastic part. That will help narrow down what it is.
Looks like it could be a SOT23-6 package.
Is it a LED driver?
Also, post a picture with surrounding components.
« Last Edit: January 12, 2024, 02:49:53 am by FactorySmoke »
Offline Martian Tech
« Reply #2 on: January 12, 2024, 02:55:12 am »
6-piin package: I guess optocoupler, with the transistor at the melted end.  But yeah, without any other context (what is it in?), it's really hard to tell.
Offline DavidAlfa
Offline fzabkar
« Reply #4 on: January 12, 2024, 03:27:13 am »
"AW=" is probably a Richtek part.
http://markingcodes.com/search/c/aw=
RT9284A-20GJ6E, Richtek, Tiny Package, High Performance, Constant Current Switching Regulator for White LED.  marking AW=, SOT23-6:
« Reply #5 on: January 12, 2024, 04:25:35 am »
It’s a Autel 906 automotive scanner.
« Reply #6 on: January 12, 2024, 04:39:58 am »
I cleaned it off some more and not sure it’s blown, it did have some black stuff running from it to the 100 chip beside it and it could be melted on the bottom. The 100 chip does get hot.
« Reply #7 on: January 16, 2024, 02:15:43 am »
Can anybody tell me what the component labeled 100 is in second picture.     This is what I think the one AW chip is.  https://www.vishay.com/docs/68393/si3438dv.pdf  Thanks
Offline coromonadalix
« Reply #8 on: January 16, 2024, 02:25:52 am »
i would say an inductor
and the Richtek Tech RT9284A-20GJ6E    seems a good candidate,   check the pinout vs the pcb and surrounding parts
for the chip  i've seen  smps controller in these packages
if the coil get hot  it means you have some short on the supply line   or a bigger current consumption
not being rude,  but the pcb  is messy / greasy   etc ...   did you try to unsolder things
« Last Edit: January 16, 2024, 02:31:28 am by coromonadalix »
« Reply #9 on: January 16, 2024, 04:13:01 am »
Yeah just flux from removing a 40 pin connector.
