Author Topic: Component identification help  (Read 720 times)
Offline matt09Topic starter
« on: April 28, 2022, 08:59:37 pm »
Is anyone able to help identify these components, I've had a look around but not managed to find anything.
The IC is PWM waveform generator and diode likely some high voltage rectifier.
Thanks
Offline fzabkar
Re: Component identification help
« Reply #1 on: April 28, 2022, 09:23:09 pm »
« Last Edit: April 28, 2022, 09:25:09 pm by fzabkar »
« Reply #2 on: April 29, 2022, 10:34:48 am »
Cheers, I thought I'd checked on there but must have missed it.
Still struggling on the IC.
Offline fzabkar
« Reply #3 on: April 29, 2022, 05:15:31 pm »
It might help if we could see the IC in the context of its surroundings. That could help us to identify the date codes and a possible manufacturer.
« Reply #4 on: April 30, 2022, 09:53:42 pm »
I'm not too sure it would be useful as it's just a PWM generator chip which feeds a FAN7384 Half Bridge gate drive IC. There are no other active components for this circuit except the FETs, unless you think other circuits on the board might be helpful?
Offline fzabkar
« Reply #5 on: April 30, 2022, 10:42:41 pm »
Could it be a preprogrammed 8-pin microcontroller?
Something like a PIC12F629/675?
https://ww1.microchip.com/downloads/en/devicedoc/41190c.pdf
Which pins are Vcc and Ground? Which pins connect to HIN and LIN of the gate driver?
« Last Edit: April 30, 2022, 11:24:52 pm by fzabkar »
