Author Topic: Component identification help needed  (Read 704 times)
Offline h3ndr1kTopic starter
« on: August 13, 2021, 12:45:04 pm »
Hi All!
I am reverse enginering a pcb from a Pet Porte 100-1023 rev 000. After a lot of hours i heve the schematics almost complete. I'm pretty sure that eny electrical engineer would want to step his eyeballs out after seeing it but it seems to be right.
I am left with two components that i cannot id.
- The first one is an transistor looking package with the text HJYQ, it's labeled U4. My current assumption is that it's job is getting the voltage down to 5 v
- The second one is also transistor looking but incredible tiny. My best quess at the text is [something] G, it's labeled Q5
Is there any one that would know how to identify these components?
If anyone would like to check the schematic and check it i would be happy to share, just let me know.
Online amyk
Re: Component identification help needed
« Reply #1 on: August 13, 2021, 01:40:52 pm »
HJxx is 24AA014
The second one looks like 1G (wipe it a little to clean some flux residue off the first character) which is probably a BC847C.
« Reply #2 on: August 13, 2021, 01:53:23 pm »
Hi Amyk,
I do agree on the BC847C, That looks like it fits.
The other link you've sent is the wrong package though... Just to be clear i'm talking about the component in red.
Offline narkeleptk
    • Youtube
« Reply #3 on: August 13, 2021, 02:09:43 pm »
How does the sot23-3 measure on pins? You mention 5v, did you measure that?
I suspect HJ is the id and the YQ is just production date.
« Reply #4 on: August 13, 2021, 02:20:50 pm »
Measured the 5v at the right lower pin
Offline fzabkar
« Reply #5 on: August 13, 2021, 06:13:01 pm »
U4 looks like an LDO regulator. The centre pin appears to be ground while the other two are probably Vin and Vout.
Edit:
This part seems to fit, but the pinout looks wrong:
MCP1702, Microchip, 250 mA Low Quiescent Current LDO Regulator, 5V, marking HJnn, SOT-23A:
https://ww1.microchip.com/downloads/en/DeviceDoc/22008E.pdf
« Last Edit: August 13, 2021, 06:28:41 pm by fzabkar »
The following users thanked this post: amyk
« Reply #6 on: August 13, 2021, 06:40:16 pm »
I will check tomorrow. Maybe it could be right!
The chunky trace you see at the top is the supply voltage, which go's to pin 3 (vin) if pin 1 goes to ground you might be right! Thank you so much in advance! I learned a lot today.
