Hi
I’ve identified a faulty component in my oscilloscope. Large round grey disc. One of the legs has become unsolder from it.
I have no idea what the component is.
I appears to be after the AC DC conversion.
The component is inline on a positive DC Rail.
Peak inrush voltage when the oscilloscope is powered on is +220 volts DC.
After power on the voltage settles down to 152 volts DC. However, display does not turn on so I’m unsure if this part of circuit is under full load.
Peak volts on power on
Peak amps DC
Test leads connected to problem component area (find large blue cap closest to multi meter, just to the right of that - not a NTC terminator inplace of the big grey disc)
I picked up some 1k 10k and 100k ohm varistors from jaycar today to try and see if this is the component type... they all pop when power applied.
I’ve tried soldering legs back into the original grey disc. But solder just beads and runs off. Cleaned and re-cleaned. Tried flux, flux solder, and flux less solder (best results but not strong connection).
If I can’t replace the part (it also seems to be functional, except for no legs)... does anyone have advice on what prep is needed on the disc to allow it to accept solder ?
Any ideas where I can get another one? Or what a modern replacement is?
Sent from my iPhone using Tapatalk
