Hi
I got myself a large air compressor with supposedly a faulty motor, the seller was told by an electrician that the motor needed to be replaced but I thought it would be a good idea to test it out myself before committing to buy an expensive replacement.
It's a 3 Hp 230V AC motor single phase, you can see in the photo that the neutral wire that's connected to the 16A breaker has overheated.
The capacitor checks out okay with my multimeter and inside of the breaker look's okay too.
I've bought a cheap insulation tester, obviously not as good as what an electrical engineer would use but adequate for what I'll be using it for, I've tested the insulation resistance at 20°C between each of the three coil wires and ground, when testing at 500V DC the insulation resistance intially would be about 400 MΩ and go up to 1000 MΩ after 5 second's and 2000 MΩ after 7 second's which is the maximum the meter will read. I know these number's should be temperature corrected to a higher temperature as the motor temp will rise when running, I read somewhere about 120°C but even so they appear to be well within what's acceptable.
I can only think that this connector on the breaker has overheated as the result of a bad connection, is the motor faulty?
Any idea, thanks?
