A fine piece of engineering from the late 80s.
I got this almost for free as it was sold defective.
Teardown first. The titles of the pictures are self explanatory. All old Hameg scopes have this common technique of using long shafts (sometimes 40cm) to turn pots and flip switches across the unit. Nowadays you get a front panel PCB with some serial interface to the motherboard. Back then you would not even think of running wires carrying low amplitude signals across the unit. Notice the build and 'personal touches'.
http://www.flickr.com/photos/alextsekenis/sets/72157626057611761/Repair now. So this scope had an issue, sometimes the display would become a dot, instead of a line. I say sometimes, and not affected by ambient temp. Initially I thought the trigger or horizontal deflection amplifier are faulty. Then I check the X-Y mode, and sure enough the deflection amplifiers were working fine. The trigger also appeared to be working, I could vary the trigger level and the trigger LED behaved normally. The component tested which uses automatic horizontal deflection also worked fine.
Cracked solder joint? Maybe! I took this baby apart and started tapping on the board with a wooden stick. Funny things happened (almost everything is analogue apart from some logic gates), but I could not reproduce the issue. I started tapping the switches, they usually oxidise after so many years. Finally, I got a glitch when I tapped next to the component text switch. Aha!
Aparently, there is a small coax cable that, for some reason, had collapsed on itself shorting out the signal to ground. Guess which signal.. the horizontal deflection ramp! Woohoo! See on the PCB, they have key signals printed on the silkscreen! Quality! To verify this, I connected the Tek DSO (now for sale) , set the function gen at 1kHz, trimmed the timebase for 1 period to span across the entire screen (10 divisions) and then measured the ramp frequency on the scope. Voila! Almost 1kHz (I had some post-trigger delay). Sure enough I could play around with that ramp with the scope's timebase settings.
Wire straightened and the beauty lives again!
