Ok, new guy here. I'm pretty familiar with electronics but this will be my first attempt at a condenser mic repair.
I have a large diaphragm condenser microphone that has developed a buzz. It gets worse when i move my hands closer to the grill. The buzz is not terribly loud, but it pretty much means i can't use the mic to record quiet sources.
I can't find a repair manual at all for this mic, a lewitt 640, and lewitt directed me to a repair shop that will at minimum cost me a couple hundred $, so I'm attempting the repair myself, without a schematic or repair manual. Worst case, i end up sending it in later. (It's out of warranty anyway.)
To me it sounds like a grounding issue, something is picking up the noise from my hands and the environment. I've already opened the mic up and there are a few circuit boards inside, as this mic has selectable attenuation and polar patterns and phantom power. Currently figuring out how to disassemble the PCBs, and being very careful.
Do you all concur with my intuition? I expect that the grill should be grounded, or perhaps there is something else around the capsule that is not grounded properly or has come loose?
Thanks,
Geoff
