Author Topic: Contact cleaner vs alcohol  (Read 32725 times)
Offline Alley_Cat_JackTopic starter
« on: May 05, 2016, 08:56:39 pm »
So I have a few old analogue oscilloscopes that need some maintenance and repair. After looking around online on what people use to clean pots and switches, I have found many answers. Those include the horrible idea of using WD-40. What is the consensus here on what is best and safest for the machine to use?
Sent from my HTC One_M8 using Tapatalk
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Contact cleaner vs alcohol
« Reply #1 on: May 05, 2016, 09:05:36 pm »
Contact spray is an acid that will eat away the oxidation, and eventually the contact itself.
Don't use that, since the device will become addicted to it.
I do not know if WD40 is acidic.
You want to use a neutral lubricant to protect it from oxidation and help sliding. As often found on CEEE plugs when they are brand new.
Obviously not a flammable one.
« Reply #2 on: May 05, 2016, 09:45:08 pm »
Will alcohol safely remove oxidation then?
Offline AF6LJ
« Reply #3 on: May 05, 2016, 09:50:36 pm »
Alchol won't remove oxidation without some elbow grease.
Silver Oxide is conductive and rarely presents a problem on switch contacts.
I use Alchol or other solvents for general cleaning. On switches and connectors I use Deoxit sparingly.
Sue AF6LJ
« Reply #4 on: May 05, 2016, 09:52:04 pm »
Not as such, however with switch/pot exercise and IPA (alcohol) you can improve things.
Deoxit seems to be the favoured product on the forum.
Offline Fsck
  • sleep deprived
« Reply #5 on: May 05, 2016, 09:59:25 pm »
they have good products for flushing and for coating.
other companies also offer good (and often cheaper) cleaners as well. you're usually aiming for some kind of alkane blend for flushing. then, potentially a product with a lubricant of some sort for long term application.
"This is a one line proof...if we start sufficiently far to the left."
Offline timb
    • timb.us
« Reply #6 on: May 06, 2016, 12:58:09 am »
The DeoxIT in spray cans is basically 5% D100 and 95% Isopropanol Alcohol, plus aerosol; this used to be called DeoxIT D5.
 I don't buy that anymore, instead I get the glass bottles of D100 (which is 100% DeoxIT) with the brush applicator (like a fingernail polish bottle) and make my own D5. Here's how:
I use 20ml glass bottles with the droppers built into the cap. I add 1ml D100 and 19ml of 91% Iso Alcohol. Shake throughly! This ends up being a 5:95 mix, just like the spray cans.
I also make up bottles of DeoxIT Gold and Shield the same way.
I use a 1ml syringe to inject the D/Iso mix into ganged push button switches from behind (inject some, operate switch, repeat) using about 0.2ml per switch. After this, let it dry for about an hour, then operate the switches for a few minutes each; this will break up any remaining oxidation. Flush with 91% Iso, blow the switches out from behind with canned air and finally, give each switch a 0.1ml shot of the D5 mix; operate each switch once or twice after injection to make sure both sides of both contacts are coated (if it's >=DPDT switch). Now, let it dry. The alcohol will evaporate and leave some DeoxIT as a coating.
For rotary switches, I use the D5 mix with the eye dropper. Basically you just coat each wafer with it and keep turning the switch. After about 10 minutes, spray it off with 91% Iso, turn the switch some more, spray again and let it dry. Then apply D100 to a foam swab applicator (Swab-It brand works well for me; *do not* use cotton applicators like Q-tips, they'll leave lint everywhere) and use it to gently scrub the metal discs on each wafer. The applicator will turn brown as it removes oxidation. Then apply a tiny drop of D100 to *each* contact on the wafer (the contacts are U shaped; the edge of the metal disc slides between them as it rotates) and work the switch for a few minutes. Wipe off excess with a clean foam swab.
You should also lubricate the ball bearings of the rotary switch. White Lithium Grease works well, but if you use it, do *not* use the canned aerosol type. It gets *everywhere* and you don't want it on the switch contacts or discs! The same applies for Silicone based spray lubricants. If you use White Lithium Grease, get a tub of it and apply it sparingly with a toothpick.
What I use is Hoppe's Number 9 with a Precision Needle-Tip Applicator. It's a mineral based lubricant that doesn't gum up or dry out. If it's good enough to keep the slide of my H&K USP working perfectly after putting 200 rounds down range, it's good enough for the bearings of a rotary switch! (It's seriously good lube. I use it everywhere; locks, hinges, reels, etc.)
« Reply #7 on: May 06, 2016, 01:03:24 am »
Wow, thanks for the guide. Any suggestions on where to get all of this?
Offline Len
« Reply #8 on: May 06, 2016, 02:18:50 am »
Deoxit is available from Active Tech www.active123.com - if you live in the right part of the country there's a store near you. :)
DIY Eurorack Synth: https://lenp.net/synth/
« Reply #9 on: May 06, 2016, 02:21:19 am »
Right part of the country, hmm? *looks outside and sees nothing but trees* nope. Lol
I live about 2.5 hours drive from the nearest one.
Offline Len
« Reply #10 on: May 06, 2016, 02:35:15 am »
Well, you can let UPS do the driving.
Offline klunkerbus
  • Electrical Engineer (retired early)
« Reply #11 on: May 06, 2016, 02:35:52 am »
I've purchased my DeoxIT D5 at Guitar Center.  I think they had a couple of different products from the DeoxIT line.  The distributor info tab on the CAIG corporate site might help with finding other retailers that carry it.  http://store.caig.com/
Offline timb
    • timb.us
« Reply #12 on: May 06, 2016, 10:35:49 am »
Amazon.com carries it, often with free Prime shipping! That's where I buy mine. 91% Isopropanol is available at your local drug store/pharmacy. I buy mine by the case at Sam's Club or Costco.
Glass bottles with eye dropper caps are available online, probably Amazon. The place I used to buy eJuice (the stuff you "vape" in an electronic cigarette) from sells their juice in those bottles, so I always cleaned them out and saved them. I've got 30, 15, and 5ml sizes. They've come in handy now and then!
I'll pull together some Amazon.com links for the various types of DeoxIT later tonight. I've been meaning to write a guide explaining the various options they sell.
Offline MrSlack
« Reply #13 on: May 06, 2016, 10:41:44 am »
DeoxIT is rather expensive. About £15+ a can here.
I bought a big can of IPA for £5: http://uk.rs-online.com/web/p/precision-cleaners-degreasers/0567890/
Cut 85 gsm Xerox paper it into strips. Wet them with the IPA. One slide through the contacts and discard. Doesn't leave any lint - I looked with a USB microscope.
IPA + toothbrush/artists paintbrush is great for getting rid of flux as well.
Offline guy48065
« Reply #14 on: May 06, 2016, 01:14:28 pm »
Contact spray is an acid that will eat away the oxidation, and eventually the contact itself....
That's news to me.  Some contain acetone.  I avoid those as they can dissolve/fuse plastics inside switches & pots.  Maybe that's what you meant?
I've used Tech Spray "Lube-a-trol" for decades but it's hard to find so now I recommend the expensive DeoxIT line.  :-+
Offline madires
  • A qualified hobbyist ;)
« Reply #15 on: May 06, 2016, 01:31:40 pm »
I'm using tuner spray for that. It cleans, lubes and protects the contacts. Works also for pots. It's not as aggressive as pure contact cleaner. IPA helps only to remove grease, gunk and such stuff.
Offline SaabFAN
« Reply #16 on: May 06, 2016, 04:31:42 pm »
Kontakt has a spray-oil that goes together with the cleaning agent.
The oil is really thin and runs everywhere until the solvent dries our, which happens in about 1 to 2 minutes. Then it leaves a thin coating of oil on the contacts and protects them from corrosion.
I have cleaned several CPU-Sockets, basically all my audio-connectors and my old Sega with these 2 chemicals and haven't seen a spot of corrosion on the connectors since.
Offline Fortran
« Reply #17 on: May 06, 2016, 04:51:39 pm »
+1 on Tuner spray. (Teslanol T6,  Kontakt und Tuner-Spray)
Works great and I haven't needed to respray any pots yet.
Can't say if it's "the best" out there or not, but I've never needed to look for anything better.
Offline ez24
  • L.D.A.
« Reply #18 on: May 06, 2016, 06:56:58 pm »
To get really confused go to DeoxIT website.  I even emailed them a question on this and got a confusing answer.  Just too many products. |O
Offline Tim T
« Reply #19 on: May 07, 2016, 05:19:17 pm »
I had had acceptable results cleaning switches of vintage test equipment using CRC mass air flow sensor cleaner obtained from a local automobile part supply store. It contains N-hexane and a proprietary compound called COzol 204,  and claims to be safe for plastic and "most sensors and connectors". Just be aware that like alcohol it is highly flammable and should not be used on energized circuits.
tim t
« Reply #20 on: May 07, 2016, 07:00:46 pm »
For grease I use a synthetic food grade grease, seeing as I had to buy a 20kg drum for work. Works well, only mildly reactive with copper ( will turn it light green after a year, so do not apply to contacts, but fine on switch bushes and open ball bearings) and the oil base is perfect for lubricating fan bearings using a syringe.
The other silicone oil I use is from Tektronix, as the Phaser transfer kit has a 2l plastic bag of drum oil in it, and the used tray ( even after resetting the counter a half dozen times, those maintenance trays were expensive) still has a litre or more of oil in it. Just transfer to a syringe and use as lubrication on metal. Guaranteed not to attack aluminium, copper or other metals, though no warranty on plastics other than nylon, HDPE and strangely PVC, as that is what the bag is made from. Still have 2 used trays ( one still in the scrapped printer) for use.
Offline HighVoltage
« Reply #21 on: May 07, 2016, 07:13:23 pm »
Alcohol to clean dirt off and then contact cleaner.
I have been using this "super contact cleaner, with poly phenyl ether"  for many years and it works extremely well.
My personal experience with this stuff is just fantastic.
Just today I fixed a broken DATEL Calibrator with it:
https://www.eevblog.com/forum/repair/datel-voltage-calibrator-dvc-8500-repair/
Offline klaus11
« Reply #22 on: May 07, 2016, 08:58:36 pm »
Where to buy in Europe the super contact cleaner
HP3458A, HP3245a, Keithley 2000, Fluke 87V, Rigol DP832, TEK TDS5052B, HP33120A
Offline helius
« Reply #23 on: May 07, 2016, 09:29:00 pm »
I mainly use it as a protectant. I found some papers that said that PPE prevents fretting and intermetallic corrosion, so I put it on edge connectors. My only complaint is that the can sprays out great gobs of the stuff when I only want a drop...
Offline HighVoltage
« Reply #24 on: May 07, 2016, 09:44:39 pm »
I buy it from Mouser.com
Free shipping over a certain invoice value and Fedex from the US delivers faster to Germany than some German companies inside of Germany.
