I think the mistakes in wiring vary, me and a relative both got one and I think both the switch and fuse on one were on the neutral side and the other the switch was on the hot side, but the fuse was on the neutral. If you do mess with the internal wiring, make sure you are right in what you do to fix it, and generally the ground should be crimped, not soldered to the wire, which I think they usually are.
