Hi all,i have an 18v cordless drill,it has a charger with a red + green led,normaly the red indicates its charging and green = when i insert the battery into the charger,a relay clicks but the green led is on,the battery is at about 14v and not charging,the red charging led never lights up,its a nicad pack not lion,the charger contacts have 21v on them,is there a thermal fuse of some sort in these batterys?,any ideas where to look?,TIA.
