Author Topic: Could someone please help me Identify this part?  (Read 1957 times)
Offline HousedadTopic starter
« on: March 07, 2017, 01:22:45 am »
I have a Acer Laptop that fell off a chair with the power cord plugged in and it messed up the jack.   However, I'm at a conundrum as to what part this is.  I have spent the last couple of days looking through the net, but to no avail.  To be honest, I don't really know where the best places are to look, so it has been a rather ad-hoc search.
The laptop is an Acer R5-571T-59DC
The Jack has what looks like possibly one SMT leg, and the others go through the board.  Thank you. (click for a larger image)
« Last Edit: March 07, 2017, 01:30:02 am by Housedad »
At least I'm still older than my test equipment
Offline amitchell
Re: Could someone please help me Identify this part?
« Reply #1 on: March 07, 2017, 01:34:24 am »
It looks like a mid-mount Barrel jack.
https://www.google.ca/search?q=3.5mm+barrel+jack+through+hole&espv=2&biw=1366&bih=750&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjDzcfsn8PSAhVN1GMKHeKXBaAQ_AUIBigB#tbm=isch&q=mid+mount+barrel+jack+&*
What is the OD and ID?
Can you power and charge via the USB-C port? Does it implement USB-C Power Delivery?
« Last Edit: March 07, 2017, 01:38:51 am by amitchell »
« Reply #2 on: March 07, 2017, 02:10:38 am »
As far as size,  the only thing I know is that the plug is 3mm x 1.1 (micro pin) and that it is mid mount.
It cannot charge through the usb.  The USB 3.0 on it will provide charge and power to devices.
Offline amitchell
« Reply #3 on: March 07, 2017, 03:09:22 am »
You could add shielded to your search term.
Likely a custom low profile part though.
« Reply #4 on: March 07, 2017, 03:32:57 am »
I hate proprietary stuff.   Will keep looking.
« Reply #5 on: March 07, 2017, 04:25:33 am »
Well, I figured out the logo.  Singatron.  On top of that, I found out that the numbers on the top are YYMMDD.  date.
« Last Edit: March 07, 2017, 04:36:36 am by Housedad »
« Reply #6 on: March 07, 2017, 05:35:32 am »
ok, i found something. It looks like the jack for the Acer CHROMEBOOK 11 CB3-111 is very similar.  Except for the plastic color, they are identical.   It takes the same charging jack as the Acer I have.  They aren't cheap at 16 bucks apiece, but I think I'm gonna try it out anyway.
http://www.ebay.com/itm/DC-Power-Jack-Socket-Charging-For-Acer-Chromebook-11-CB3-111-C670-CB3-111-C4HT-/282227364139?hash=item41b60fd12b:g:TL0AAOSwHsRYCXPe
Offline amyk
« Reply #7 on: March 07, 2017, 11:50:01 am »
It's worth asking them, but from their catalog it looks like a 2DC3079. Maybe you could try asking for a sample...
