Electronics => Repair => Topic started by: Housedad on March 07, 2017, 01:22:45 am
I have a Acer Laptop that fell off a chair with the power cord plugged in and it messed up the jack. However, I'm at a conundrum as to what part this is. I have spent the last couple of days looking through the net, but to no avail. To be honest, I don't really know where the best places are to look, so it has been a rather ad-hoc search.
The laptop is an Acer R5-571T-59DC
The Jack has what looks like possibly one SMT leg, and the others go through the board. Thank you. (click for a larger image)
(http://i.imgur.com/1n0OFsQm.jpg), (http://imgur.com/1n0OFsQ)(http://i.imgur.com/CQQ3Zwam.jpg) (http://imgur.com/CQQ3Zwa)
(http://i.imgur.com/kkw4Vr9m.jpg) (http://imgur.com/kkw4Vr9),(http://i.imgur.com/SJqtpkzm.jpg) (http://imgur.com/SJqtpkz)
(http://i.imgur.com/8n6B2Fpm.jpg) (http://imgur.com/8n6B2Fp)
It looks like a mid-mount Barrel jack.
https://www.google.ca/search?q=3.5mm+barrel+jack+through+hole&espv=2&biw=1366&bih=750&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjDzcfsn8PSAhVN1GMKHeKXBaAQ_AUIBigB#tbm=isch&q=mid+mount+barrel+jack+& (https://www.google.ca/search?q=3.5mm+barrel+jack+through+hole&espv=2&biw=1366&bih=750&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjDzcfsn8PSAhVN1GMKHeKXBaAQ_AUIBigB#tbm=isch&q=mid+mount+barrel+jack+&)*
What is the OD and ID?
Can you power and charge via the USB-C port? Does it implement USB-C Power Delivery?
As far as size, the only thing I know is that the plug is 3mm x 1.1 (micro pin) and that it is mid mount.
It cannot charge through the usb. The USB 3.0 on it will provide charge and power to devices.
You could add shielded to your search term.
Likely a custom low profile part though.
I hate proprietary stuff. Will keep looking.
Well, I figured out the logo. Singatron. On top of that, I found out that the numbers on the top are YYMMDD. date.
ok, i found something. It looks like the jack for the Acer CHROMEBOOK 11 CB3-111 is very similar. Except for the plastic color, they are identical. It takes the same charging jack as the Acer I have. They aren't cheap at 16 bucks apiece, but I think I'm gonna try it out anyway.
http://www.ebay.com/itm/DC-Power-Jack-Socket-Charging-For-Acer-Chromebook-11-CB3-111-C670-CB3-111-C4HT-/282227364139?hash=item41b60fd12b:g:TL0AAOSwHsRYCXPe (http://www.ebay.com/itm/DC-Power-Jack-Socket-Charging-For-Acer-Chromebook-11-CB3-111-C670-CB3-111-C4HT-/282227364139?hash=item41b60fd12b:g:TL0AAOSwHsRYCXPe)
It's worth asking them, but from their catalog (http://www.singatron.com.tw/ftp/3C/Singatron-DC.pdf) it looks like a 2DC3079 (http://www.singatron.com/pdfs/DC_POWER/2DC3079-007111F.pdf). Maybe you could try asking for a sample...
