Author Topic: ZD-937 - Problem reading temperature  (Read 1899 times)
Offline mau80Topic starter
« on: January 16, 2017, 07:42:35 am »
I've a problem with this soldering station, it always shows TEMP 428°C, even if i detach the solder cable I get TEMP 428°C.
I've replaced the heating resistance and termocouple, the soldering iron temperature is hight, but it always display 428°C.
Let me know if I can provide other details to you.
Thank you very much to all!
Maurizio
Re: ZD-937 - Problem reading temperature
« Reply #1 on: January 26, 2017, 10:54:45 pm »
Hi to all,
I've solve the problem. This model use 4 din connector, I've used following connections:
1 Heat
2 Thermocouple +
3 Thermocouple -
4 Heat
Maurizio
