Author Topic: Coupler on old Hameg scope  (Read 1814 times)
Offline p2potterTopic starter
« on: March 18, 2021, 10:11:46 pm »
I retrieved my long lost Hameg HM204-2 from my attic and after a round of Deoxit, it looked pretty good. However, I noticed that one of the couplers from the front panel to a pot had broken. Attempts to glue the plastic back together failed as the torque of the set screw just splits it again (see pic).
I can find metal replacements on Amazon that should work, but they are metal rather than plastic. Would this be an issue? The coupler that is broken joins a 3" metal rod to a metal push switch/pot wiper for the trigger level control.
I could not imagine this being a safety issue, but possibly this might introduce some noise. Does anyone see any concerns with this repair? Not really important as this is my backup for my Siglent, but its always nice to have good working test equipment.
Thanks in advance,
Phil
Offline bob91343
Re: Coupler on old Hameg scope
« Reply #1 on: March 18, 2021, 11:57:28 pm »
I think metal should work fine.
Offline jdragoset
« Reply #2 on: March 19, 2021, 12:12:40 am »
Try drilling two 0.035 holes (one each side of set screw) parallel to the shaft and use some SS safety tie wire, twisted tightly.
Glue and most plastics rarely work unless specifically intended.
Two long #1 bolts and nuts (m-1) would also work in place of the tie wire.
« Reply #3 on: March 19, 2021, 02:34:40 pm »
Guys,
Thanks for the responses. I think i will just buy a coupler from Amazon and see how it works out. If it is not satisfactory for any reason and can try the drilling and screwing approach.
Thanks,
Phil
Offline BrokenYugo
« Reply #4 on: March 19, 2021, 07:58:16 pm »
Might also try a chunk of vinyl or rubber tubing. I've made couplers that way that lasted in more demanding service.
Offline KevinA
« Reply #5 on: March 19, 2021, 10:17:39 pm »
At my last company. I broke down an HM203-5 for parts (boss did not want to pay for output transistors).
PM me if you want his details.
« Reply #6 on: March 21, 2021, 04:07:19 am »
KevinA,
I think(?) is sent you a PM, but reply here if you did not get it.
Thanks,
Phil
Offline KevinA
« Reply #7 on: March 21, 2021, 05:26:48 pm »
His website is
http://www.conference-services.co.uk/index.php
The guy is not technical, and he has had no staff since I retired four years ago, so you will have to send him a good photograph of what you need. Also, tell him it is in bin 505, which is at the very back of the workshop, adjacent to the roller shutters.
Price wise, I would start by offering £0.10 plus postage; I know he is wanting to sell up.
Before you get excited and make him an offer for everything, there are around 100k of spare parts, and 20k of service manuals - whoever takes it need a big warehouse.
Offline fossi
« Reply #8 on: March 24, 2021, 07:44:24 pm »
Some weeks ago, I had the same problem.
At first, i made one part on my lathe out of isolating material.
Then I remarked that I need some more parts.
I found a link and ordered there some of the couplers, because they are very cheap and it is not worth to make the parts by my own.
The dealer is
 https://www.sky-messtechnik.de/reparaturdienst-service/hameg-ersatzteile.
It was no problem to get the parts within 2 or 3 days. The guy is very helpful. You can ask for parts, which are not on the list and if you have luck you can buy this parts to for a moderate price.
I don't know if he is sending the parts to US.
regards
fossi
The following users thanked this post: shakalnokturn
Offline shakalnokturn
« Reply #9 on: March 26, 2021, 01:14:45 am »
37-Z100-0310    Achskupplung, Ø4XØ2x15mm    €   4,00
37-Z100-0312    Achskupplung, Ø4XØ4x20mm    €   4,00
37-Z100-0314    Achskupplung, Ø4XØ4x25mm    €   4,00
37-Z100-0316    Achskupplung, Ø4XØ6x25mm    €   4,00
37-Z100-0318    Achskupplung, Ø6XØ6x25mm    €   4,00
« Reply #10 on: March 27, 2021, 12:20:32 am »
Thanks everyone for the responses. I will contact various folks as the second picture in the last post is exactly what i need. The Amazon coupler i bought works, but it is big and looks really ugly (bright metallic blue!).
Thanks,
Phil
Offline oz2cpu
    • webx.dk private hobby and diy stuff
« Reply #11 on: December 31, 2024, 04:50:44 pm »
sorry to kick alive old thread,
but i just solved the same problem , same broken nylon part, same Hameg brand
I 3D designed and 3D printed the part, works perfectly fine,
I also shared the file for free on thingiverse
https://www.thingiverse.com/thing:6894218
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
The following users thanked this post: Greybeard, cte
Offline cte
« Reply #12 on: December 31, 2024, 05:40:27 pm »
Maybe I can add to this...
I needed replacement for the red plastic part used on the vertical amplifier board for the "5x magnification".
My solution has to be printed in two halfs (one has to be mirrored) and then glued together.
⚡ To avoid electric shock, ensure that your instrument is correctly grounded.
Offline oz2cpu
« Reply #13 on: December 31, 2024, 05:55:10 pm »
CTE thanks for sharing
did you also put the files free available on thingiverse or similar ?
Offline cte
« Reply #14 on: December 31, 2024, 05:56:43 pm »
No, not yet. Never made an account there. Maybe I should...  :clap:
