Alrighty ! update time, first off you guys are awesome, great suggestions to give me a direction.
I sucked the SRAM chip off one board and immediately the current draw dropped to ~2.5-3.0µA ! So I figure that's definitely the culprit ! I need to get better with the hot air though, even with foil around it i still melted the jumper just above the SRAM.
I suspected this might be the case only based on the one board that did still work but failed to do the "clear" on initialisation so i bought 2 replacement SRAM chips a few weeks back which arrived on Thursday.
Bad news is NEITHER of the replacement chips work at all. The board is basically 'dead' with them installed. Re-install the "semi-working" SRAM back onto the board and its alive again but with the same fault. The other good news is the second board that seemed totally dead, when i swapped the semi-working SRAM onto that board, it comes to life but also fails to "clear" so i know that the fault is that SRAM and now i guess i should find a better source than eBay for replacement chips.
Once i get them i'll update whether that totally fixed it or not.
