Author Topic: Crimp box format socket to fit 0.05" (1.27mm) square PCB pin  (Read 1395 times)
Offline perdrixTopic starter
« on: January 08, 2018, 02:34:28 am »
I initially thought this would a a simple item to find, but it seems it's a bit harder than that.
The chopper PCB in the HP 3420 has two 0.05" square PCB pins to which I need to connect two wires - so easy?
No - I've so far been unable to locate a free crimp socket to fit a 1/20" square pin.
Any suggestions most welcome
Thanks
Dave
Offline pamphonica
Re: Crimp box format socket to fit 0.05" (1.27mm) square PCB pin
« Reply #1 on: January 08, 2018, 10:54:05 am »
This series is 0.045" square and might provide a basis for experiment.
http://www.molex.com/molex/products/datasheet.jsp?part=active/0009503021_CRIMP_HOUSINGS.xml#partdetail
Jeremy
