Don't try adjusting anything, something has obviously failed. I wish I had a dollar for every monitor, TV, etc that somebody has rendered uneconomical to repair by twiddling every adjustment they could find when something failed.
First thing I would check is the power rails, especially the B+ that is feeding the video amplifier. Also take a look at the CRT heaters and see if they're glowing the normal yellowish orange. The video amplifier is clipping, that's what makes the streaks to the right, and the picture is very dim, suggesting some of the voltages may be low. Electrolytic capacitors are a common fault.
