Hi and THANKS for the reply!!! How do you know that there's a bleeder resistor and where is it on the schematics (just want to learn question)? BTW I saw that C308 +C309 is 35V on the schem.
THANKS!!!
R103 is in parallel with C109 and will gradually discharge it. It's still a good idea to check the voltage on that cap before you stick your hands in there!
You don't have to worry about discharging the CRT unless you need to removed the HV connection from the side of the CRT. Also, this design uses the focus and screen controls as a bleeder resistor.
If you ever do need to discharge the CRT, it's simple to do. Just ground a screwdriver to the grounding strap for the conductive coating that's on the outside of the CRT with a clip lead. Then, slip the screwdriver under the rubber cup until it touches the metal contact. If you hear a snap, then leave it connected for a few minutes so all the charge bleeds off.
